tjpsnj
Aug 01, 2022Guide
HomeKit Setup warning
HomeKit Setup Warning Since purchasing my Netgear RAX70 AXE x8 Router, each time I open my iPad I get a HomeKit Setup Warning to logon iCloud. How do I disable whatever it is on the router triggerin...
tjpsnj
Aug 01, 2022Guide
I disagree. Something in the router is triggering the unconfigured software in the iPad. the only change I made is the adding the RAX70. If I go to my girlfriend's house the warning does not popup.
The router is reaching out to the iPad.
Further and just like your link the 'home' app is removed from my iPad since it first became annoying years ago.
Aug 01, 2022Guru - Experienced User
There any Access Controls, Armor or SPC enabled on the router?
