aspiller98
Dec 22, 2019Guide
Horrible 2.4GHz Speed
I just exchanged my Google wifi at best buy for this new netgear RAX120. Unfortunately I can't exchange again or get a refund... I am stuck with this router that is worse. When using 2.4 within 10 fee...
- Feb 18, 2020Yes I found the issue. If you plug anything into the usb ports on the router it kills 2.4g. I unplugged my hdd from it and it instantly fixed it
aspiller98
Dec 23, 2019Guide
I got it two weeks ago. Yes, 5G works fine. When using 2.4G and looking right at my router with line-of-sight from 30 ft away it drops to unusable link speeds or doesn't work at all. I also noticed that I drop like 20-30% of packets as well when it does it.
Dec 23, 2019Guru - Experienced User
I would open a support case since it's only 2 weeks old.
- welchyboyFeb 18, 2020Star
Did you have any luck? I have the same issue? I have terrible wifi speeds on my rax120. A speed test straight from the router is good but wifi it is crawling.
- aspiller98Feb 18, 2020GuideYes I found the issue. If you plug anything into the usb ports on the router it kills 2.4g. I unplugged my hdd from it and it instantly fixed it
- plemansFeb 18, 2020Guru - Experienced User
Good (but bad) to know. I'll have to let others know with that issue on that router.
