aspiller98's avatar
Dec 22, 2019
Horrible 2.4GHz Speed
I just exchanged my Google wifi at best buy for this new netgear RAX120. Unfortunately I can't exchange again or get a refund... I am stuck with this router that is worse. When using 2.4 within 10 fee...
  • aspiller98's avatar
    aspiller98
    Feb 18, 2020
    Yes I found the issue. If you plug anything into the usb ports on the router it kills 2.4g. I unplugged my hdd from it and it instantly fixed it
