Mask0mimi
May 30, 2023Aspirant
Horrible download speeds over ethernet- Nighthawk RAXE500
Over the past couple of weeks, I have been experiencing really poor download speeds over Ethernet. Every single speed test website shows a drastic drop in my download speeds with the exception of ...
Mask0mimi
Hey Guru, thanks for the quick response.
There is no modem in between the router and the wall-jack which serves as my ISP's source of internet. Again, when connected to the wall-jack, I get the full speed
I have already tried two separate cables i.e. Cat6 and Cat7 with no luck.
I am using a Desktop PC which is connected via Ethernet and am able to reproduce the issue consistently.
I have already tried upgrading to another firmware provided by NetGear's team and have also powercycled to no avail.
I have also erased the router and re-onboarded it as per Nighthawk's instructions and again have not seen much difference.
May 30, 2023Guru - Experienced User
What does the WAN port speed show on the routers web page for Show Stats button on the Advanced Tab?
