tradyan
Jan 26, 2020Aspirant
Horrible wifi speeds + occasional drop of Internet
Hello all, I just purchased the RAX120, and I am really struggeling, for 2 reason 1) My 2019 MBP is alternbatinav betweeen 10mb/s to 50 at the most. My iphone 11 pro is at the same time on ...
tradyan
Jan 29, 2020Aspirant
Hi Christian
1) Ax is enabled, when i disabled it WIFI speed dropped to under 1mb/sec. Smart conenct is also enabled
2) Router is on, only internet drops. Less then a min at the time
Regards
T
Christian_R
Jan 31, 2020NETGEAR Employee Retired
Hi tradyan,
Thanks for confirming. Please try disabling smart connect and let me know if your issue persists. I've also sent you a message, please respond at your earliest convenience.
Christian
- tradyanFeb 01, 2020AspirantWill try disabling once im back home, however, it’s defying the whole purpose if I end up with 2 different SSIDs
- tradyanFeb 03, 2020Aspirant
tried to disable, not much of a differnce on download, upload got better
on 2,4ghz 24 mbps
on 5 ghz 26 mbps
upload went from 20-22 to 33
on phone speeds are better, always where
