Wristlock
Jan 26, 2026Aspirant
how bad is this ?
Nighthawk AX6 6-Stream AX5400 WiFi Router(RAX50) Nighthawk 2.5Gbps Cable Modem (CM2000) connection is slow and unstable and the logs are always dos attacks [DoS attack: RST Scan] from ...
Jan 26, 2026Guru - Experienced User
Wristlock wrote:connection is slow and unstable
If you reboot the router, does the connection start off ok? Or is it just as slow right after the restart?
If you remove forwarded ports, anything in the dmz, and disable upnp, does the problem disappear?
If not, then one option is to try saving the config, doing a factory reset of the router, and then restoring the config. If the problem doesn't disappear after the reset, you could try contacting your ISP.
