Wristlock
Jan 26, 2026Aspirant
how bad is this ?
Nighthawk AX6 6-Stream AX5400 WiFi Router(RAX50) Nighthawk 2.5Gbps Cable Modem (CM2000) connection is slow and unstable and the logs are always dos attacks [DoS attack: RST Scan] from ...
Wristlock
I have rebooted the router and it seems just as slow at restart. I will try disabling upnp, check for any port forwarding and look in dmz, factory reset, then report back.
Are the DoS attacks a concern ? Thank you
Jan 26, 2026Guru - Experienced User
What devices do you have all connected. The one IP address ACK scan is from Amazon. You might turn OFF all devices that connects to the router save one ethernet PC and see if those UNKNOWNs stop being logged.
