Wristlock
Jan 26, 2026Aspirant
how bad is this ?
Nighthawk AX6 6-Stream AX5400 WiFi Router(RAX50) Nighthawk 2.5Gbps Cable Modem (CM2000) connection is slow and unstable and the logs are always dos attacks [DoS attack: RST Scan] from ...
Jan 26, 2026Guru - Experienced User
What speed do you get wired?
What speed do you get directly from the modem hardwired into it?
What speeds do you pay for?
Got a copy of the modem logs and the cable connections page from it?
I always prefer to start at step one (the modem) and work up from there.
