partyk1d24
May 27, 2021Aspirant
How can I access routerlogin.net or IP after setting custom DNS (without reset)?
I have a NightHawk RAX35 and I just configured it to hit my pihole for DNS. However, since I have done this I have not been able to access the admin page. I normally would plug in to the ethernet por...
May 27, 2021Guru - Experienced User
did you setup the pihole to handle dhcp as well?
If you're using the 10.0.0.1 address are you also running another router on the network? (whats the rax connected to for gateway)
It could be a double nat issue.
partyk1d24
May 30, 2021Aspirant
Sorry for the late response on vacation. As for the way the network works, the other "router" is the ATT fiber box (sorry don't have the model rt now). I tried to get a lighter weight brick but ATT said there wasn't one for 1gbs.
I did not setup DHCP on the piHole because I had externally acessible endpoints so I wanted to use the router. Can I change that after the fact without the router UI?
Thank you!
