Ragetti
Jun 30, 2020Tutor
How can i find out or set my local domain name?
Hi all, How can I find out my local domain name or set one within the router config? I am using the RAX200 as my DHCP on my local network and the router&modem (supplied by my ISP) just as my ...
michaelkenward
Jul 01, 2020Guru - Experienced User
What does that mean? Domain names are not router territory. Or are you talking about DNS?
If you want your own WAN (Internet) IP address, use one of the usual tools.
Ragetti
Jul 03, 2020Tutor
Here is a screengrab of the pi-hole text
