bata
Jun 10, 2019Aspirant
How can I setup parental controls on the RAX120 router
It seems there is no parental control options in the Nighthawk App for the RAX120. How can I set up parental controls on the RAX120? Thanks,
- Jun 10, 2019
There is currently no Parental Control on any Netgear RAX router available.
You can look into https://www.opendns.com/home-internet-security/ - there are "ready-made" Family Shield (different name server IP addresses, not the standard OpenDNS ones) available for free - and configure the router accordingly.
schumaku
Jun 10, 2019Guru - Experienced User
- bataJun 10, 2019Aspirant
Thanks for the info. I tried the OpenDNS FamilyShield dns server addresses on the router and it didn't seem to be blocking adult sites
Thanks,
- schumakuJun 10, 2019Guru - Experienced User
On it's own it won't ... business as usual, just addign these two addrreses to the router won't make it happen immediately. DNS caches mut be emptied, clients must use either the same or the router for DNS only, ... but hey, we're not OpenDNS support here.
Thanks. Got it setup with OpenDNS.
