KangHH12
Dec 02, 2022Aspirant
How can i solve network speed asymmetry?
Hi my router is RAX38V2 and I use it in SouthKorea I use 500MB speed Internet On my computer, Internet speed is good download 450MB / uplode 450MB but on wifi, internet speed asymmetry d...
michaelkenward
Dec 02, 2022Guru - Experienced User
download 450MB but uplode 160MB
That's how wifi works. It will never be as fast as a wired connection.
Do these wifi clients give much better speeds on different wifi sources?
By the way, you might like to investigate the use of Alt + Print Screen to take pictures of your screens.
