SeanWangTaiwan's avatar
Jan 24, 2021
How could I just enable the 5G wifi only? (also using smart connect)
I want to disable the 2.4G wifi signal and only enable both 5G wifi with smart connect function.
How could I setup my router?
  • plemans's avatar
    You can't.
    With smart connect, you need all 3 radios enabled.
  • schumaku's avatar
    schumaku
    For what? If the conditions are good, the majority if not all of clients will operate on 5 GHz anyway.
