DannyLin
Mar 15, 2022Apprentice
How do I add my RAX120 back to the Nighthawk app?
I accidentally removed my RAX120 from my Nighthawk app on iPhone. The Rax120 still connect to the Internet, but I was unable to add it back to the app to manage it. How do I add it back? Tried t...
Mar 15, 2022Guru - Experienced User
Have you just tried factory resetting it and starting back from factory?
Push and hold reset for 7-15 seconds while its powered on
- DannyLinMar 15, 2022ApprenticeNo, I did not. I know that will work, but then I will lose all my settings on my Rax120.
It is also weird to do a factory reset, especially when my Rax120 works appropriately. I’m looking for a solution to simply just add it back to the app so I can manage it via the app.- plemansMar 15, 2022Guru - Experienced User
I've never tried to remove a device from the app. So not sure if you can add it back in.
You could always make a backup of your configuration to save time on the reinstall. Plus backups are always good to have.
