Eroszero
Dec 01, 2022Aspirant
How do I change the password on my router
any help with changing the password? The videos do not help.
Dec 01, 2022Guru - Experienced User
Which PW? Admin log in PW or WiFI SSID name and PW?
What NG router do you have? R or RAX or XR or RBR?
Review the online User manual for your model router here:
Eroszero
wifi ssid and pw.
- FURRYe38Dec 01, 2022Guru - Experienced User
Need to log in to the routers web page with a PC and web browser, usually at 192.168.1.1 and check out the Basic Tab/Wireless settings section.
- michaelkenwardDec 01, 2022Guru - Experienced User
Eroszero wrote:
wifi ssid and pw.
How do I change the WiFi password or security level on my NETGEAR router? | Answer | NETGEAR Support
How do I change my NETGEAR router password or network name (SSID)? | Answer | NETGEAR Support
