ThomasKarp
Oct 04, 2023Tutor
How do I connect a USB printer to my RAX50v2 router ?
How do I connect a USB printer to my new fancy Netgear RAX50v2 router ? Brother 2040 Printer Windows 11 Is the USB port on my router meant for storage only ? Thank you !
- Oct 05, 2023
ThomasKarp wrote:
Is the USB port on my router meant for storage only ?Over the years, Netgear has whittled away at the things you can do with USB. Many devices, especially Mesh routers, don't even have a USB port.
The manual for the RAX50v2 says nothing about printers. So you are probably out of luck.
You say this is a "new fancy" router. Do you still have an old one that supports USB printing? If so, you could put that into AP mode and see if you can use it as a print server.
I use this strategy now that I have an MR90 router without a USB port.
Does this printer also have Ethernet support? The manual for "Brother 2040 Printer" doesn't pin it down.
michaelkenward
Oct 05, 2023Guru - Experienced User
ThomasKarp
Oct 14, 2023Tutor
Thank you for your answer.
I guess I could use the old router as an AP, but I think I'll try to sell it.
My place is too small to make good use of an AP, I think I'll be making too much radio noise, unless I will disable most of the WiFi, except for what's needed to make the AP working. Hmm ... maybe I could make a cascade the AP wired and disable it completely.
Yes, I was being sarcastic with "fancy new router". I am a bit disappointed.
I always favoured Netgear products, in my mind they should come with reliability, features, trust, innovation.
The interface, web UI access is just flat, lacks good visual appeal and organization, seems like a programmer design it, no offence to programmers.
I was also hoping the restart time, router reboot on save settings, would be improved but no, 2min is still the standard.
It's the same as 5 years ago.
Thanks again !
