morrismc
Nov 19, 2019Aspirant
how do I connect my internet coax to my Netgear Nighthawk Ax8
I purchased the Netgear Nighthawk Ax8 router with the intent to replace my internet provider's router. I want to cut the TV and Phone from my existing provider's plan and keep internet only. There is...
Nov 20, 2019Guru - Experienced User
You don't say who your isp is but if you recieve internet service via coax you will need a modem. The RAX80 is a router only device (best route). You need a modem seperate. Or you can return the RAX80 and get a combo device that has a modem and router together. I'm not a fan of these as then the isp controls the firmware as well as if something goes wrong, you're out both devices.
Who is your ISP? Usually they have a list of compatible modems based upon service you plan on using.
michaelkenward
You can get some idea of why this is sound advice by looking at how many cable modem/routers Netgear sells.
Cable Modem Routers | Networking | Home | NETGEAR
A handful.
Compare that with the router range.
Wifi Router | Wireless Routers for Home | NETGEAR
Dozens.
This tells me that you get a much wider choice of features in routers.
Just put a cable modem in front.
- morrismcNov 23, 2019Aspirant
Yep, Cable modem in front of the router is the solution. Thanks
- michaelkenwardNov 23, 2019Guru - Experienced User
When looking for a cable modem, best look for a "modem only" number.
Many modems are really modem/routers. That just makes like more complicated ... and expensive.
