dgoswami
Jul 19, 2021Follower
how do i enable link aggregation on my RAX200
I have wanting to enabled link aggregation on my netgear nighthawk RAX200 router , I did enable the LAG on the router through the web interface and connected the 2 ethernet cables in parallels connec...
Jul 19, 2021Guru - Experienced User
I've used the SB8200 with my RAX200 (and an RAXE500 and a Arris w31).
At no point in my testing was the sb8200 stable or even consistent on speed.
I was in a beta and addressed it with arris but never got much for positive feedback on the fixing the arris.
My CM1100 was much more stable.
What speeds do you pay for?
What speeds do you get and how are you testing?
