ChungKing
Jan 29, 2022Aspirant
How do I get a USB drive to show up in Windows? I have a Nighthawk RAX48..
I had an older Linksys router with a USB drive attached. Worked fine, just needed a faster router with better speeds and better wifi range, etc. I hooked up the new router just fine. I plugged in...
michaelkenward
Jan 30, 2022Guru - Experienced User
ChungKing wrote:
I hooked up the new router just fine. I plugged in the USB drive and went to ReadyShare to give it a name. I have no idea how the heck to get it to show up in Windows 10 on my desktop (wired) and laptop (wireless).
Does that mean you actually set it up in ReadySHARE?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Share USB Storage Devices Attached to the Router
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
ChungKing
Jan 30, 2022Aspirant
I think it was pretty clear I already set it up in ReadyShare. I just need to get it to show in Windows now. The manual instructions did not work for me. This website doesn't make it immediately obvious that there's other forums I could post in. I'll try there.
- michaelkenwardJan 30, 2022Guru - Experienced User
Not really. All you said was :
As a long-time user of ReadySHARE, I know there is more to it than that.
But if you think you have done everything with ReadySHARE, and don't want to go into more details, fine.
I suspect that your problem is with Windows. Perhaps you could take a cue from the messages you get and ask Microsoft for help. Netgear doesn't have much control over what happens on your desktop.
- ChungKingJan 30, 2022Aspirant
michaelkenward wrote:
ChungKing wrote:I think it was pretty clear I already set it up in ReadyShare.
That's all you need to do in ReadyShare is give it a name and point it to the drive and done. You can set a password requirement if you want. I tried both ways. The Linksys router all I did was set it up in a similar fashion and I was able to map it. The Nighthawk not so.
