SchulteOmaha's avatar
SchulteOmaha
Follower
Mar 30, 2022
HOw do i get the Security KEy??????
1 Reply
  • plemans's avatar
    wifi security key?
    What key exactly?
    What device do you have?
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
