IraSch
Mar 06, 2025Aspirant
How do I just access my router without logging in to Netgear's Account?????
I have a Netgear RAX54v2 router and I just want to get to the admin screens. Every time I want to go there, it requires me to login to some Netgear account site. And half the time that doesn't even...
Mar 06, 2025Guru - Experienced User
IraSch
That thread seems to be talking about Access Denied issues, not the problem of forcing the user to login to a Netgear Account (and that not working). Is there a way to turn off the Account Login requirement and just let me get to my router admin screens?
- FURRYe38Mar 06, 2025Guru - Experienced User
That's the issue is that that admin log in is not appearing and is showing a different NETGEAR account.
Once you do the factory reset and setup from scratch with the router not connected to the ISP modem, complete the setup wizard, then reconnect, you'll get the normal admin log in screen to get in to the routers web page.
- IraSchMar 06, 2025Aspirant
Hmmmm - strange. The account I'm trying to log in with is the account used when I bought the router 6 months ago. Is there a way to turn off this Login requirement? I can get into the router if I disconnect from the internet - so is there a setting that will turn off the Login requirement?
ALL NG routers have a admin user name log in and pw requirement that can't be disabled.
