ReubenPrichard's avatar
Jun 29, 2020
How do I purchased a MK60?
I purchased an MK62 & MK20 solution prior to the ability (new firmware) to add the second MK60. I've spent a bunch of time on the Netgear website and there is no data available and NO Presales support link (terrible support at best) to answer how I can purchase a second MK60? Right now the only way I can see is to order a new three node-set. This is totally ridiculous!
Any guidance is most appreciated!
R Prichard.
  • michaelkenward's avatar
    michaelkenward
    MK60 isn't a model number that I can find. Do you mean MS60?
    MK is the tag for a "kit" that bundles router and satellites. Satellites have their own model numbers
    ....there is no data available and NO Presales support link (terrible support at best) to answer how I can purchase a second MK60? Right now the only way I can see is to order a new three node-set.
    Start with looking for the right thing and try this:
    MS60 - AX1800 Nighthawk Mesh WiFi 6 Satellite | NETGEAR
    • ReubenPrichard's avatar
      ReubenPrichard
      Typing too fast... MS60 is the correct specification. Sure I can get to the page to order the MK62 set (router and satellite), AND, I can add the extra MS60, but I can't
      just order an MS60. If you have a link to "add to cart" for a single MS60, please post.
