aemilianvs
Mar 19, 2025Aspirant
How do I reset the VPN client certificates?
Hi community, Anyone knows how can I reset the / create new VPN client certificates as the initial ones might have been compromised? Thank you!
michaelkenward
Mar 20, 2025Guru - Experienced User
Which VPN is that?
Disclaimer: Just another user with time on their hands.
aemilianvs
Mar 24, 2025Aspirant
It's the VPN server of the router. I would need to regenerate the certificates that the server/router provides so that clients can connect using them.
- KitsapMar 24, 2025Master
Do you use a Dynamic Domain Name Server (DDNS) service?
Whether you use a free or paid DDNS service, a user name, domain name, and password is required. These items are part of your VPN configuration in the router you set before generating the VPN files for the client device.
Go back to the DDNS service and change the password or better yet, create a whole new account with a new domain name and password.
Reconfigure your router VPN server and use the new DDNS information. Then create a new set of VPN configuration files for the client device. The old configuration files will no longer work with the new router configuration.
- aemilianvsMar 24, 2025Aspirant
Thank you for taking the time to respond! I don't have DDNS (and I don't need it, afaik). I only have a fixed IP. The router has its own VPN server which has the security certificates I download for the clients to connect. I am talking about generating new certificates that the server would recognise. Hopefully it makes sense.
Thanks again!
aemilianvs wrote:Thank you for taking the time to respond! I don't have DDNS (and I don't need it, afaik). I only have a fixed IP. The router has its own VPN server which has the security certificates I download for the clients to connect. I am talking about generating new certificates that the server would recognise. Hopefully it makes sense.
Thanks again!
I understand what you are asking for. The series of generated certificates encrypt the router serial number and the DDNS password.
You cannot change the serial number and if you don't use DDNS, it is going to be difficult. As far as I know, the Netgear Open VPN implementation makes no provision for username and password protection for access to the Open VPN server.
- aemilianvsMar 25, 2025Aspirant
I have created a netgear ddns account and hostname and seems configured. When I download the certificate, it seem to be the same as the old one (based on the signature and public key), so it doesn't seem like it's been re-generated. I can't find an option to re-generate it manually.
- KitsapMar 25, 2025Master
The client key file is an encrypted binary.
When you created new configuration files after adding the DDNS details, that was a manual regeneration of the files.
Recommend you do your own testing to satisfy/confirm the old files do not allow remote access and the new files do allow remote access.
