alexsts
Apr 21, 2022Follower
How I can open ports on Nighthawk router R6700AX?
Hello,
I need to open couple very specific port on the router. So far I can not find any place where it can be done.
Question 2.
For some reason password which I set for router is working only for the internal Wi-Fi connections, but nobody can connect to the apps from outside.
It shows that password is incorrect.
Funny thing that once you get connection inside, apps continue to work outside of router range (on opposite side of the city for example).
What is wrong with that thing?
1 Reply
Review NGs many KB articles for Port Forwarding or Triggering as well:
