Preesen
Jan 15, 2022Aspirant
How many devices can this router RAX40 connect to
What does this specs from Amazon website mean: WIFI Coverage : 2,000 sq. ft., 20 devices Does this mean the router can only connect to 20 devices in total?
Preesen
Jan 16, 2022Aspirant
Thanks for the response.
Does that mean it can only connect to 40 Devices in total (2.4GHz and 5GHz) ?
That seems quite low considering the router provided by the ISP can do 64 devices.
I do know that it won't deliver the performance but just want to know the total number of device connections possible on this router.
microchip8
Jan 16, 2022Master
Look up its manual on NETGEAR's site. It may mention how much
- PreesenJan 16, 2022Aspirant
Will do. Thanks
- michaelkenwardJan 17, 2022Guru - Experienced User
There may also be a KnowledgeBase article along these lines:
How many clients can you connect wirelessly to a NETGEAR router? | Answer | NETGEAR Support
and
How many devices can my Orbi system support? | Answer | NETGEAR Support
