Omar-
Sep 11, 2024Aspirant
How many RAX10-100NAS can be managed from a single web interface?
We need to buy several AX1800 (RX10) Wi-Fi routers and put one in each site. can someone tell what is tha max number of this router can be managed from a single web interface? for example : we would ...
Sep 11, 2024Guru - Experienced User
Remote management using routers web page is no longer supported. Only remote management is used thru the Nighthawk app.
When older routers supported remote web page management, only could access a signal router per site at a time.
Omar-
Thanks! do you know the max number of routers I can link to nighthawk?
also is there any current netgear router that supports both web interface and app management?
- FURRYe38Sep 11, 2024Guru - Experienced User
All NG routers have a web UI management page. Just have to be locally connected.
I believe you can have many routers connected to the NH app. Not sure how the app handles same model router though. I presume it will separate them due to the serial number being different.
