Omar-
Sep 11, 2024Aspirant
How many RAX10-100NAS can be managed from a single web interface?
We need to buy several AX1800 (RX10) Wi-Fi routers and put one in each site. can someone tell what is tha max number of this router can be managed from a single web interface? for example : we would ...
Omar-
Thanks! do you know the max number of routers I can link to nighthawk?
also is there any current netgear router that supports both web interface and app management?
Sep 11, 2024Guru - Experienced User
All NG routers have a web UI management page. Just have to be locally connected.
I believe you can have many routers connected to the NH app. Not sure how the app handles same model router though. I presume it will separate them due to the serial number being different.
