CBV
Jul 19, 2020Tutor
How to activate purchased Armor on iOS app for RAX120
Hi All,
Has somebody know how to activate a purchased Armor on iOS app for RAX120 router. I had tried different options but still having the message of "Process is taking to long (more than 60 secs), Try again!!", when try to active on Netgear app.
I a did a factory reset on my router, uninstall and reinstall the app in iPhone Xs. I did check on the Armor web and the suscription appers activated and my router shows activated tooo, but in the app and router web is not.
Router model: RAX120 / AX6000
Firmware version: V1.0.1.122
I'll appreciate any help or support.
Thanks
1 Reply
- Christian_RNETGEAR Employee Retired
Hi CBV,
What is the app version of the Nighthawk app you currently have installed? May you send me a private message with your email address and serial number.
Christian
