ctviggen
Dec 08, 2024Initiate
How to block a website (Netgear Nighthawk RAX45)
I am trying to block a website from anyone. I tried this:
Entered the website as "www.websiteIwanttoblock.com", where "websiteIwanttoblock" is the name of the website I want to block. This does nothing I can see. That is, I can easily go to the website I supposedly just blocked.
Is there a way to block specific websites using the Netgear router I have?
Netgear Nighthawk RAX45, latest firmware.
If my router cannot do this, is there another router that can?
Sort By
the problem is that most sites switched to https that encrypts the information. It made website blocking more challenging.
Most switch to a DNS blocking setup using something like opendns
https://www.opendns.com/home-internet-security/
- ctviggenInitiate
Thank you. I remember when we looked into this last time that the problem was each device already encrypts the signal that's being sent. So, you'd have to decrypt it.
I'll look into that DNS blocking setup.
good luck!
