ruson's avatar
ruson
Follower
Jun 22, 2023
How to block tcp/udp ports between devices in WLAN (my router: Nighthawk RAX40v2)?
There is one requirement for blocking some tcp/udp ports (for instance 5353) between devices connected with same Netgear AP, ie. WLAN. I tried the "Advanced" -> "Security" -> "Block services", but it does not work. I guess that option is just for ingoing or outgoing traffic between internet outside and inside devices.
Thanks!
1 Reply
  • Not supported blocking LAN to LAN ports, only LAN to WAN. The latter is what "block services" does
