carlos0248
Jul 10, 2024Follower
How to change my RAX10 region?
I bought a RAX 10 router, but I find the signal is so weak. I want to change the region but the region option is blocked. How can I change the region from China to Other country?
1 Reply
If you mean the wifi region, this is locked on to the market where this device was sold.
It is set by local laws and regulations. If you are not in China, then you have been sold something intended for that market and should get back to the supplier.
On the other hand, wifi signal strength usually follows an international standard. Local markets will determine which channels you can us.
