ramesh_iyer's avatar
ramesh_iyer
How to check if my RAX10 router is transmitting in Wi-Fi 6 mode
I had bought the RAX10 Wi-Fi 6 router 2 years ago. But back then I didn't have any device which is Wi-Fi 6 capable. Few months ago I got a new smartphone which is Wi-Fi 6 capable. Yet, I notice that ...
  • Kitsap's avatar
    Kitsap
    Jan 30, 2024
    ramesh_iyer wrote:
    Both my smartphones - Motorola G54 and Samsung A34 are 5G capable and as per manufacturer info are also Wi-Fi 6 capable. Neither of them connect to my Netgear RAX10 over Wi-Fi 6, as mentioned earlier.
    You are confused by the terminology.  In the world of cell phone connections, 5G refers to 5th Generation connections to cell towers.
    I looked up the specifications for both of your cell phones.  Neither is capable of connecting to Wi-Fi 6.  Attached is a two page PDF file with links to the specification pages and screen snips of the Wi-Fi connection capability.  One page for each phone model.
    For reference, here is a link to a good document regarding Wi-Fi understanding.
    https://www.wiisfi.com/
