ramesh_iyer
Jan 30, 2024Aspirant
How to check if my RAX10 router is transmitting in Wi-Fi 6 mode
I had bought the RAX10 Wi-Fi 6 router 2 years ago. But back then I didn't have any device which is Wi-Fi 6 capable. Few months ago I got a new smartphone which is Wi-Fi 6 capable. Yet, I notice that ...
- Jan 30, 2024
ramesh_iyer wrote:Both my smartphones - Motorola G54 and Samsung A34 are 5G capable and as per manufacturer info are also Wi-Fi 6 capable. Neither of them connect to my Netgear RAX10 over Wi-Fi 6, as mentioned earlier.
You are confused by the terminology. In the world of cell phone connections, 5G refers to 5th Generation connections to cell towers.
I looked up the specifications for both of your cell phones. Neither is capable of connecting to Wi-Fi 6. Attached is a two page PDF file with links to the specification pages and screen snips of the Wi-Fi connection capability. One page for each phone model.
For reference, here is a link to a good document regarding Wi-Fi understanding.
ramesh_iyer
Well, my devices do connect over 5Ghz but they show "Wi-Fi 5" not "Wi-Fi 6" which is the issue.
Kitsap
Jan 30, 2024Master
ramesh_iyer wrote:Well, my devices do connect over 5Ghz but they show "Wi-Fi 5" not "Wi-Fi 6" which is the issue.
Both Wi-Fi 5 and Wi-Fi 6 transmit over the 5 GHz frequency band. Your router may not have the Wi-Fi 6 transmission enabled. Look where FURRYe38 said to look to see if Wi-Fi 6 is enabled.
- ramesh_iyerJan 30, 2024Aspirant
Yes, AX mode is enabled, and sso are OFDMA for both 2.4 & 5Ghz. Hence my query.
