ramesh_iyer
Jan 30, 2024Aspirant
How to check if my RAX10 router is transmitting in Wi-Fi 6 mode
I had bought the RAX10 Wi-Fi 6 router 2 years ago. But back then I didn't have any device which is Wi-Fi 6 capable. Few months ago I got a new smartphone which is Wi-Fi 6 capable. Yet, I notice that ...
- Jan 31, 2024
ramesh_iyer wrote:Both my smartphones - Motorola G54 and Samsung A34 are 5G capable and as per manufacturer info are also Wi-Fi 6 capable. Neither of them connect to my Netgear RAX10 over Wi-Fi 6, as mentioned earlier.
You are confused by the terminology. In the world of cell phone connections, 5G refers to 5th Generation connections to cell towers.
I looked up the specifications for both of your cell phones. Neither is capable of connecting to Wi-Fi 6. Attached is a two page PDF file with links to the specification pages and screen snips of the Wi-Fi connection capability. One page for each phone model.
For reference, here is a link to a good document regarding Wi-Fi understanding.
ramesh_iyer
Jan 31, 2024Aspirant
Thanks mate for your efforts and clarification with PDF (though I prefer referring to the manufacturer's product page on their website, and not GSMArena which sometimes gets tech specs wrong). But yes, both both phones do seem to have only Wi-Fi 5 capability as per your PDF as well as on brand sites. I wrongly mistook Wi-Fi 6 to be 802.11ac but it's ax.
BTW, I mentioned 5G as most mid-range 5G phones seem to have Wi-Fi 6 now a days. Anyways, it's clear now. Thanks again.
Kitsap
Jan 31, 2024Master
You are welcome. Glad you got it sorted.
