lvchen860217's avatar
Feb 17, 2022
How to check the connection duration of RAXE500
How to check the connection duration between the client and the raxe 500, including wired and wireless connections. I want to know if any clients disconnect occasionally.
I remember that there is a table of DHCP connection duration in linksys mx5300, which shows the connection status(e.g 12h:50min:22sec) between each client and router. Can raxe500 have this function to view?
  • FURRYe38's avatar
    I don't believe NG routers have this feature.
  • Altsai's avatar
    Altsai
    NETGEAR Expert
    >>> No, current RAXE500 does not support this feature.
