mtho2014
Aug 26, 2022Aspirant
How to connect to internet via ethernet on NETGEAR Nighthawk AX5400 WiFi 6 Router
How do I switch from wifi to an ethernet connection? I plugged in the ethernet cord to my mac and changed the service order on my network preferences to ensure the ethernet connection had priority ov...
michaelkenward
Aug 27, 2022Guru - Experienced User
mtho2014 wrote:
How do I switch from wifi to an ethernet connection? I plugged in the ethernet cord to my mac and changed the service order on my network preferences to ensure the ethernet connection had priority over wifi, but it wasn't giving me internet access.
That's probably a problem for your Mac.
What does "it wasn't giving me internet access" mean.
Is "it" the Mac or our router?
mtho2014
Sep 05, 2022Aspirant
oh okay, so all I should have to do is plug in the ethernet cord and I should have access, right? for some reason as soon as I plug into the ethernet cord I lose internet access.
Just making sure I don't have to switch another setting on my router preferences in order to use the ethernet connection.
