chuck4100
Dec 31, 2019Tutor
How to determine the fan status on RAX120
Hello, I have been getting some full failure type issues with my router recently, like reboots don't help but a full factory reset sorta did. Mainly, I noticed that at no point have I seen the f...
Christian_R
Jan 03, 2020NETGEAR Employee Retired
Hello chuck4100 & Fricke_Iowa,
If your router is getting warm and causes the router to shutdown, I would recommend getting in contact with our Support Team for further assistance.
https://www.netgear.com/support/default.aspx
Christian
