Theo10mm
Sep 29, 2022Aspirant
How to Disable WPS on RAX50 Router (Part II)
I guess I struck a nerve with my last same topic and response because my thread was deleted/blocked/moderated. I am unable to access the thread. But anywho.... How to Disable WPS on RAX50 Router?...
Sep 29, 2022Guru - Experienced User
From what I see with my RAX50, there is no manual way of disabling of the WPS button. From what I understand though the service is idle only and only activates when the button is pressed. So someone has to phsycally press the button to do anything with WPS. Or if you disable the wifi radios on the router, this disables the WPS button and service as well.
