zhangs02000
Oct 01, 2022Follower
How to find R6700AX Router IMEI? It is NOT labeled on the router.
How to find R6700AX Router IMEI? It is NOT labeled on the router, as it usually do for other model. It might be in the packing box, but who keep the box?
Oct 01, 2022Guru - Experienced User
imei is a mobile device identification number. What makes you think the R6700AX has one? Its not a mobile device
