F34R's avatar
F34R
Tutor
May 25, 2021
How to get best performance from Nighthawk AX120 (transfers over home network)??
So, I'm transferring files from my PC to my iPad.  Doing over my wifi network since it's faster than USB transfers.  My PC is connected to the RAX120 via Ethernet, while my iPad is connected to the 5...
  • plemans's avatar
    May 26, 2021
    hitting 400-750mbps is pretty darned good for transferring between devices with one of them wireless.
    I'm not sure what speeds you're expecting from it as many variables impact data transfer speeds between devices.
