F34R
May 25, 2021Tutor
How to get best performance from Nighthawk AX120 (transfers over home network)??
So, I'm transferring files from my PC to my iPad. Doing over my wifi network since it's faster than USB transfers. My PC is connected to the RAX120 via Ethernet, while my iPad is connected to the 5...
- May 26, 2021
hitting 400-750mbps is pretty darned good for transferring between devices with one of them wireless.
I'm not sure what speeds you're expecting from it as many variables impact data transfer speeds between devices.
May 26, 2021Guru - Experienced User
F34R
May 26, 2021Tutor
Oh I agree that it's a good speed as is, but I was just seeing if it could be pushed further. Just wanted to reach out and see if this is the best, or are there other things I can do to increase it. If not, no biggie, no complaints. The router has been rock solid for just under 2 years now.
- plemansMay 26, 2021Guru - Experienced User
tough to say. like I said, there's a ton of variables.
1. different OS's
2. different file types
3. different formatting to the systems
4. different ssd read/write speeds and cache's
5. wireless performance/interfrence for the wireless device
6. network overhead
7. different device performance (cpu/ram/etc)
plus more since this was just a quick list.
I couldn't even give you a realistic expectation between devices. I have 2x servers and can get entirely different speeds based on what drive the data is on, what format the drive is on, etc.
- F34RMay 26, 2021Tutor
plemans wrote:tough to say. like I said, there's a ton of variables.
1. different OS's
6. network overhead
Yeah, I was considering all that basically. I was running the file transfer from my main pc, and the only traffic was the PC and iPad.
I didn't think there was anything wrong, but I figured it doesn't hurt to ask. Maybe there's something I missed that would improve the speed. Someone else replied in the subreddit that my speeds are very close to maxed with 2 antenna spacial streams available for the iPad. Much appreciated for the replies for sure.
