Shak2022
Jan 15, 2022Follower
how to increase speed
how do i increase the speed of the internt using srk60 (orbi Pro), i have 650 mps downlaod but cannot figure out how to get the wifi to incrase to that speed, i am only able to go up to 350mps. ...
Jan 16, 2022Guru - Experienced User
The bottleneck isn't usually the router but the device you're using.
What device are you testing speeds on?
How are you testing speeds?
You might get better advice in the forum for your device.
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
