curiouselging60
Oct 14, 2024Aspirant
HOW TO INSTALL ROUTER AX 1800 ON DESKTOP
- Oct 15, 2024
You don't. There is nothing to install.
You can use a desktop and a web browser to set up a router.
Which device do you have? AX1800 is not a unique Netgear model number. Many devices come with the AC/AX tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
Look at the label on the device for the Model Number. And, if there is one, include the "V" bit to show the hardware version. If there is no V number, then you have V1.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.That page will also have any software, firmware and drivers for your device, if they exist.
Begin with the Quick Start/Installation Guide.
Check the section in the manual Manually set up the Internet connection
There may also be some helpful videos on what to do.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
Just another user with time on their hands.
michaelkenward
Oct 15, 2024Guru - Experienced User
Support | NETGEAR
curiouselging60
Oct 18, 2024Aspirant
thanks.
now to find someone so I can reset, not recover, my dell computer w/win 10.
computer cant do it. micrsoft can't do it, but will get back to me and no
AI directions work either. just one of those things I guess.
