Steveborough
Sep 06, 2019Tutor
How to set port speed on Nighthawk AX8?
I have a connected thermostat device that works for 1 minute while connected (wired) to this router. The manufacturer advised to switch the router port from Auto to 100Mb, which the device uses. I do...
michaelkenward
Sep 07, 2019Guru - Experienced User
Why? Are you having problems with the device?
Sounds like the manufacturer does not understand this stuff.
Your router will negotiate a speed with the LAN stuff connected. It isn't something you set in the router.
If it barfs after a minute, I'd look elsewhere for the problem.
Have you tried different LAN ports for this device? The RAX80 does tricksy stuff.
- SteveboroughSep 07, 2019Tutor
Its faily common to have to set port speed and turn off auto for certain devices, that is why the option exists (at least on every other router ive ever seen). Some hardware does not work well with some auto-sensing ports. Its a common practice when setting up older devices and some modems.
Connected to every other ports and still the same thing, I put a small wireless repeater with an ethernet port in between the thermostat and the ax8 and it works again. But this is not ideal, as the repeater causes wifi congestion, wifi speeds drop to 30Mbps while its on, (I have 1Gig internet)
