NickEs
Mar 30, 2023Aspirant
How to set the RAX45 as a wireless repeater?
Hi, all. I have a new tri-band router as my main router (necessary because of MoCA), but the WiFi is not as strong as I'd like it to be -- so I'd like to set up my previous RAX45 as a repeater. I'v...
Mar 31, 2023Guru - Experienced User
What actual router do you have?
Why not look into just using an extender instead of trying to make a router work?
Kitsap
Mar 31, 2023Master
If you have the option to run an Ethernet cable between your new router and the RAX45, then configure the RAX45 as an access point.
- NickEsMar 31, 2023Aspirant
Yes, that was my backup plan. Here's what I've done:
1. Went into my Verizon router, and assigned the Nighthawk a static IP of 192.168.1.222 (via the MAC address).
2. Disconnected the Verizon router from the PC.
3. Connected the Nighthawk to the PC (using a Nighthawk LAN port, not the WAN)
4. Logged into the Nighthawk at 192.168.1.1.
5. Changed the SSIDs.
6. Under "LAN Setup," turned off dhcp.
7. Changed the router mode to "AP." While it was rebooting:
8. Disconnected the PC end of the cable and moved it to the Verizon LAN. The Verizon and Nighthawk are now connected, LAN to LAN.
It SEEMS to work. We'll see if it helps/
- KitsapMar 31, 2023Master
NickEs wrote:Yes, that was my backup plan. Here's what I've done:
Very good! A couple of notes about your configuration. When you configure a router as an access point, the DHCP function is automatically disabled. The DHCP function for your LAN is now handled by your upstream router.
For the input to your access point, the WAN connection will work just fine. On your access point, your LAN connections are fully functional Ethernet ports if needed.
- michaelkenwardMar 31, 2023Guru - Experienced User
For future reference, if it is not practical to run Ethernet cables around the place, or the family hates the idea, I have used Powerline Ethernet to run routers in AP mode.
