JimTurkey
Sep 23, 2021Guide
How to set up Nighthawk AX5400 RAX50 w/ U-Verse BGW210?
I just bought the Nighthawk AX5400 RAX50 because of the terribly slow wi-fi I am experiencing in my house. However, before it arrives, I wanted to make sure I completely understand the set-up process...
JimTurkey
Sep 25, 2021Guide
I found this tutorial linked below. It is using the Orbi as an access point.
Do these directions seem to be correct in your opinion?
https://forums.att.com/conversations/att-internet-equipment/how-to-connect-orbi-wifi-to-an-att-modem/5f2ace04917fbb7b950106e6?amp;wtExtndSource=20210429183921_AT&source=ESSZ0SSPR00facsEM&wtExtndSource=20210518220621_AT
Sep 25, 2021Guru - Experienced User
That option will work. It puts the orbi in access point mode which disables some features.
- JimTurkeySep 25, 2021Guide
plemans wrote:That option will work. It puts the orbi in access point mode which disables some features.
After reading that link, it looks like the access point option might not be the best. It limits what Orbi can do. Am I right?
Or I found this video that goes through IP Passthrough, turning off the BGW210 wifi, and other steps. Ah! This is so confusing. Why can't there just be 1 way?
- plemansSep 25, 2021Guru - Experienced User
Because att makes you use their modem/router gateway.
When you get it, try a method and see if it work for you?
