Snopczynski
Feb 01, 2020Aspirant
How to setup Priority for Xbox one on RAX80 AX6000
Hi All, I am hard wired from my xbox one with cat 6 to a Netgear AX6000. I was wondering how to set the xbox one as the top priority device when it is on and being used? The xbox speed test is defini...
Snopczynski
Feb 07, 2020Aspirant
Do I want to enable the automatic QOS database update?
How do I give the Xbox one priority over everything else hooked to the router when the xbox one is turned on or being used?
Snopczynski
Feb 11, 2020Aspirant
Hello?
- rw5sFeb 12, 2020Initiate
I would enable QoS and automatic QOS database update, you might as well check for updates here as well. Click Apply and wait for settings to update. From my experience this should be enough to support your Xbox playing CoD online with crossplay.
I have an AX8 I just set up a couple weeks ago. I get 400-450 Mbps download speeds with a wired connection, and about 300Mbps a few rooms away over wifi. I also have xbox one, and play cod with crossplay on, while connected to this router Wirelessly, nonetheless. We have some other minimal network traffic running at the same time as well.
To take this a step further, turn the Xbox on and make sure it is connected to the router. You can then go to your router settings (I just use the web interface, not the app), select Home > Attached Devices, and it should show Xbox One, you can edit and change Deviec Type to Gaming Console and its priority to Highest. I've read these settings sometimes can get erased, but I just set this up last night, I'll check again tonight to see if the settings are still there.
- SnopczynskiFeb 13, 2020Aspirant
Thank you, I will give this a whirl. I am basically trying to get all the speed I can out of the house when i am playing. The PC guys seem to have the upper hand on us console guys with speed.
- rw5sFeb 13, 2020Initiate
For sure, I believe there's an advantage with keyboard and mouse too, unfortunately not much to do about that one.
