alpac
Jun 24, 2022Aspirant
How to setup time for RAX 120
Can somebody tell me how to set up the actual time of the day on the RAX 120 so as the logs show the correct time and not 1h behind?
Thanks
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- alpacAspirant
Never mind I finally found out that the time zone setting is under Advanced->Administraton->NTP Settings
Enjoy. 📡
