jconway1006
Mar 21, 2020Aspirant
HP Printer and RAX120
Hey All,
So a few weeks ago I got the RAX120 Went to print something today via Wifi and noticed my printer wasn't connected. HP Laserjet Pro 200 (M251 I believe) Pretty sure its a wifi setting. But not sure what one. Anyone have a similar issue with their printer?
Thanks in advance.....
- TopologyVirtuoso
Jconway1006, you may wish to try configuring a static IP address for the printer (see the router’s webpage ADVANCED | Setup | LAN Setup | Address Reservation). After doing so, you will need to power-down/power-up the printer for the change to become effective.
- jconway1006Aspirant
Not sure why i didn't think of that. I does give me a wpa password error or something. I'll try the reservation first. Then post the other error if it doesn't work.
The usual way to fix wifi printers is to find the printer maker's utility, the software that runs on your operating system. Then use that to connect the printer to the wifi.
The router just broadcasts wifi. It is then down to the printer to play ball. There isn't much that you can do on a router, beyond fixing it to a particular IP address, that affects what the printer gets up to.
Where possible, using the WPS feature can simplify things.
- LeeHProdigy
I had that problem too. I always setup my Laserjets with static IP's starting at .200 It took two printer reboots on two days in order for it to show them connected. They are always showing as being connected now. Don't know why they were showing up as not connected at first but are working fine for the last two weeks. Mine are wired.
- jconway1006AspirantIt’s only with this router. Didn’t do it with the last one I had. Definitely has something to do with the newer technology in this router. My guess is if I put it to the lowest 2.4g settings it will work. The new “ax” technology is to new for the printer.
I only use it when printing from my iPad and I have other ways around that.- NewfiedroolVirtuoso
Sometimes drivers need updating so worth checking if there's any for the printer.
insure TX is on in advanced settings on router.
Don't use 40ht on 2.4 as some printers don't like this, use 20ht if you are on 40ht.
