jconway1006
Mar 21, 2020Aspirant
HP Printer and RAX120
Hey All, So a few weeks ago I got the RAX120 Went to print something today via Wifi and noticed my printer wasn't connected. HP Laserjet Pro 200 (M251 I believe) Pretty sure its a wifi setting...
Newfiedrool
Mar 23, 2020Virtuoso
Sometimes drivers need updating so worth checking if there's any for the printer.
insure TX is on in advanced settings on router.
Don't use 40ht on 2.4 as some printers don't like this, use 20ht if you are on 40ht.
Topology
Jconway1006, it may be beneficial to disable Protected Management Frames on the RAX120, which are enabled by default. Disabling PMF is designed to “fix legacy wireless client and printer connection issues,” according to Netgear.
Please see the router’s webpage at ADVANCED | Advanced Setup | Wireless Settings | Disable PMF.
- jconway1006Mar 23, 2020Aspirant
Yeah still won't connect.... Apprectiate the help though....
- NewfiedroolMar 23, 2020Virtuoso
Put the router in ac mode and try
